Heating & Cooling Logo
Anonymous Posted on Jan 15, 2011
Geno, Thanks for the reply. Ironically I found the website this afternoon that you sent me links to later. Thanks for your kindness. If I get someone else the problem is continuity test on both elements of Rheems 40 gallon water heater tested fine. Power to upper element but no power to lower element. Trying to determine to replace one or both thermostats. Below is volt test I did on top thermostat connections. T4 and L4 bring power to lower thermostat from top one. No power reads when tested lower element. I did a volt test based on the diagram on this website. L3 to T2 is to have power - NO POWER (Problem) L1 to L4 is to have power- Did have power L3 to L4 is not to have power- Ok with no power L3 to T4 is not to have power- OK with no power L3 to T2 is to have power- NO POWER (Problem) L3 to T4 is to have power- Did have power So does this still indicate both Thermostats to be replaced? Are you a plumber by the way? Thanks so much! Tom
  • Anonymous Jan 16, 2011
    Thanks for the reply. Used an analog not digital meter but it stayed far right near 0 for both. Tested a new element and got the same reading. I guess I am surprised there is no power to the lower element- at least showing on the meter-but I am no electrician or plumber.
Mack Baxter
Level 3:
Master:
  • Master 383 Answers
  • Posted on Jan 16, 2011
Mack Baxter
Master
Level 3:
Master:
Answers
383
Questions
Helped
74763
Points
1139
Hi Tom,
I'm not Geno-- But maybe I can pick up where he left off?
First you say you did a continuity test on the heater elements-- What was the Ohms on each?
Now to the Voltage measurements:
You say you have voltage to the upper-- but not the lower--
That is normal on a cold tank-- That way you can get HOT water faster, that waiting for the whole tank to heat (as from the bottom element-- Make sense?
Until we know if the elements are OK-- the voltage checks are a bit pre-mature.
So-- With power shut OFF, and the wires lifted from the heating elements,
What are the ohms across the heater elements themselves?
(It should be low-- in the 3 or 4 ohms?-- but NOT OPEN! (which is infinity..)
What do you get?
Mack B
  • Mack Baxter Jan 16, 2011
    OK Tom-- That is good thinking-- comparing your OHMs on the installed heaters, with OHM on a new one!-- Great thinking!
    So-- since we are pretty confident that the installed elements are OK-- let's trace the voltages coming in.
    Did you let the heater try to heat the tank?
    For as I said before-- It is normal for just the TOP element to get voltage during start-up. This speeds the delivery of SOME hot water at the top of the tank (where all the hot water is drawn off from).
    So-- are you getting hot water ? Do you hear the element sort of bubbling and crackling as the water heats AT THE TOP ONLY?
    As the top thermostat gets satisfied,-- IT THEN TURNS ON THE POWER TO THE LOWER ELEMENT-- and then it concentrates on heating the WHOLE TANK.-- Make sense?
    One more thing to think about:
    If a heating element is OLD, and if you have a lot of Calcium building up around it (at the Bottom of the tank)-- The element can get overheated (due to a lack of good water circulation-- from too much calcium in the way..)
    When it overheats, the element breaks thru it's metal jacket, and it can give a low resistance 'short' to ground. This can fool our Ohm meter into giving us a reading that LOOKS good,,, The best check for that, is an Ammeter (A clamp around kind) -- then we know we have current going thru the element, and HEATING WATER.
    If you can get a hold of a clamp-around Amp meter, that might help you confirm that both elements are drawing the right number of amps.
    Let me know what you need next-- I will be away most of the day-- I'll be back tonight to check on you..
    Mack B
1helpful
Can You send me a picture as to where it hook up? I have been to several sites AND HAVE NOT FOUND INFORMATION.
I have no idea what kind of a picture you want. Never post a reply like this, use the email link you were sent when the expert answered you on the original question..
1helpful
2answers
How do i fix a petrol leak from the relay which holds the fuel injectors
No glue or sealer of any kind will work here. The fuel rail is under considerable pressure. I assume that your leak is between the fuel rail and the injectors(?). If this is the case, the o-rings on every fuel injector should be replaced. If you have further information or questions please reply here and I will be back later this afternoon. :)
if the fuel rail itself is cracked or broken, a new one or one from a reputable salvage yard is recommended before welding. These kind of leaks present a very extreme fire hazard!
1helpful
Why can i not follow a link to my answer ? i click the link and therte is nothing pertaining to my answer / problem
Hi RON JAMES,We have sent you an email regarding this as well as information on how to access your solution, to your registered email address. We kindly ask that you check your email.
Please feel free to contact us again either here or by replying to the email and we will be happy to assist you.
FixYa Support Team
NEED INSTRUCTION MANUAL FOR 30XS CALCULATOR!
I found two(2) links for your scientific calculator !!!
Link 1 http://www.math.wisc.edu
Link 2 http://education.ti.com
Kindly reply for follow up.
Thanks.
Mongkey
2helpful
2answers
Please sent HP Desk jet Printer F 2120 software\driver
From this official link you can choose your op. system (win XP, Vista, win 7) and download the drivers you are looking for.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
22helpful
5answers
I got sms from TD-hrinfo that resume selected by company , letter is attached , how i can download letter by link yourfilelink.com/get.php?fid=571029
got sms from TD-hrinfo that resume selected by company & offer letter is already sent to in my mail id,but till today i can not get any mail from your side
Vision XO D1740BT
may i know your email add: i contact you in there.
regards
micro
Top Heating & Cooling Experts
Paul Carew
john h
