Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 60" Sony
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jan 15, 2011
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957323
Points
33084
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
My tv is an older model 60inch screen. I believe it is a hdtv lost the owners manual on one site it said the model number is on the remote. The number on the back of tv is worn away. How do I find the...
All Sony sets have a duplicate label or labels inside the set; this would require unplugging the set and removing the back.
Older projection sets have for the most part model numbers beginning with KP (like KP 57ws500) and the newer ones have KDF etc.
If the white label on the back cannot be read you will have to open set and look for duplicate labels inside----much like cars where the vin number is in several places.
SD TECH
Grand Wega KDF-60WF655 ...The picture has recently gotten dark....with cable, dvd's, and vhs tapes...
The tv projection lamp live is ending.Change the tv projection lamp,will solved this problems.
1helpful
2answers
Blue blothes on LCD screen
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Picture on Sony KDF-60WF655 has a yellow tint after 30 mins on
This TV is known for issues with the optical block(light engine) The discoloration is coming from the LCD panels in the light engine that have been damaged by the intense heat produced by the lamp. There is a class action lawsuit settlement between Sony and the New York state attorney general's office. Sony agreed to cover these problems going back 4 model years. if you had to pay for the repairs on this TV, you could expect to pay more than $1000 to replace the light engine. Call Sony customer relations at 1-800-222-SONY
and tell them you want this covered per the agreement I mentioned.
Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Screen is dead
TV screen dead symptom..I need info about Sound, and standby light at TV front. Is there sound comes from TV? does standby light lit when switch on TV?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
