SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
SOURCE: shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
SOURCE: Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
SOURCE: Tub shower diverter stem on tub spout broke and
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
