Question about Dell Office Equipment & Supplies
I can no longer make copies or fax.The printer makes a deep churning noise and grinding sound. I can however print copies from the computer. goodwinjma@sbcglobal.net
  • 97 Answers
It sounds like the problem is in the "Scanner " on the computer. You need to call a service tech
Posted on Jan 15, 2011
SOURCE:
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
I have seversal problems -- The Scanner Lock is on and I can't figure out how to turn it off. Now I can't copy or fax. The machine makes a grinding noise when I turn it on. I think this started after...
The lock is a slide switch next to the large glass when you open the top cover, when it is locked the scanner can't move and makes a grinding noise. It's easy to bump into the locked position and easy to unlock.
Sep 02, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Copying function not working
para imprimir la hoja de calibracion no la jala
Oct 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Open Questions:
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
