SOURCE: Ice machine works great, but will not dispense
I just repaird a unit with this same symptom. Yours may be the same. The plastic part that holds the switch was broken (pins). See the diagram at http://www.partselect.com/Schematics/Whirlpool/KAZVHYR3.gif Item 15 is the part. The switch sets on a coupld pins and the pins break easily, thus the switch falls off and the dispensor lever can't operate it. If you look up inside with a flashlight you can see the switch, etc. and should be able to tell if it's held in place properly.
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
