Check the micro switch that the brew unit hit when it enters the machine. Sometimes the lever arm on the switch breaks off, and the switch will no longer work. Click the link for a picture of the micro switch.
Micro switch for saeco and gaggia machines
SOURCE: Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
SOURCE: Saeco Magic Comfort plus: Despite descaling the
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Testimonial: "Fast, correct and thorough. The cryptic Manual was less than clear but your instructions were excellent. thank you"
SOURCE: Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
