Motorola Mobility V360 Cellular Phone Logo
Posted on Jan 15, 2011
When i try to access my internet it says 413 page cannot be opened. my network provider could not help me you are my only hope
Dragon kumar
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jan 15, 2011
Dragon kumar
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
6772
Points
58
Dude delete all your cell ph setting and restore the phone,ask for new setting from ur network provider and save them
How to open mms in android samsung mobile the mms which i have received
Hello Sanju
I assume there might be MMS settings which you need to get from your service provider.
You can try these steps
Click on Settings ' Wireless and Network ' Mobile Networks - and ensure "Use packet data" is on.
Also.. in the same menu window - enter Access Point Names and ensure that you have your network provider's MMS APN configuration in there. Some network providers can send the configuration to you by their website or a phone code.
Some network providers might request you need to have at least a WAP or Internet APN (Access Point Name) configuration before MMS gets delivered to your mobile phone... if the above still doesn't help you download MMS, install a WAP or Internet APN configuration through your network provider - (by: Naith_KK)
Hope this should do the trick.
Feb 18, 2014 • Cell Phones
tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 • Computers & Internet
How to access my n2730 to the enternet?
You can access various internet services with your phone browser. The appearance of the web pages may vary due to screen size. You may not be able to see all the details on the web pages.Depending on your phone, the web browsing function may be displayed as Web or Internet in the Menu.
Use only services that you trust and that offer adequate security and protection against harmful software.For the availability of these services, pricing, and instructions, contact your Network service provider.You may receive the configuration settings required for browsing as a configuration message from your Network service provider.
1.Open the configuration message from your Messaging Inbox.
2.Select Options > Save.
3.The GPRS (General Packet Radio Service) settings will be saved to your phone.
4.Restart your phone.
5.Select the correct access point to connect to the internet.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Page is not open
Try open other site if the same appear try to diagnosed your internet connection and try re-opening the FACEBOOK again if the words page is not open appears again there is a problem with your internet connection and contact your internet service provider.. Hope this will help you..
My wifi says its connected but it won't open sites, help me
1--go to the network settings under control panel and see if it says there that the internet is connected or not . 2--try shutting your wifi off and then turn it on . you can even try restarting your system . 3 -- try connecting to an alternate network . 4-- if it says it is still connected and you can not access any website , try opening the same web site in an alternate browser . 5-- lastly if it still shows connection bit fails to open any page , do this --- click Start + R . or go to Start>Accessories>Run . in the window that opens type this --- ping google.com -t . and then hit enter . if the internet is working you should see this message " Reply from 74.125.230.116 : bytes 32 time 102 secs TTL " this shows the net is working ( website replying back ) . then the website you are trying to access might be down . If you get a message like - " request timed out . " or " host unreachable " ,,, then your Internet provider is having a down time ...
hope it helps
1helpful
How to open the packet data?
Hi keich...
To open packet data Goto
Menu>Web>Browser or Goto Address
Enter address>ok
If it gives any error
Try the following
*First contact your network operators customer care check whether internet service of your number active or not If it's already active request them to send internet settings save and activate these settings
if problem persists Restore factory settings by Menu>Settings>Restore Factory Settings>(Default Security Cide will be 12345)
Then also problem persists contact your network operators customer care ask the accesses point name(you can create a internet setting manually by Menu>Settings> Configuration Settings>Personal Con Settings>Web>you can enter home page as you wish(ie:any website id) select "use pref access pt"to no>Access pt settings>Proxy to "Disable">Bearer settings>Packet data acc pt>enter the access point what they provided
I hope this helps.....
Than you
Router problem
Hello!
Here is a guide on how to setting up port forward on DSL 500T for uTorrent:
http://www.portforward.com/english/routers/port_forwarding/Dlink/DSL-500T/Utorrent.htm
If you can't reach the router as described in the link above, than you need to contact whoever provided you with this router. If the router was provided by your ISP (internet service provider) than contact them directly asking how to access your router.
Hope this helps!
Airport has signal
The airport has a wireless signal but its not supplied by your provider. In order to use wireless at the airpport you have to pay their provider too.
Your system can receive and send to the wireless network in the airport but usually when you have connected to their wireless network, once you open a browser (IE or Firefox) it will provide you with a sign up page where they want you to pay typically $9.99 for 24 hours of use of their wireless network, which you sign up for with a credit card.
So you should be able to recieve that page but you can't access the rest of the internet unless you pay them for access.
Sorry
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
