Sounds like calcium build up, You need to descale the machine.
If you look at the grounds on the basket, After the brew cycle is over there is like a hole in the center of the grounds. This happens when there is calcium build up in the tank, tube and or spray head. And takes forever for the brew cycle to end.
Follow the instruction on your manual to descale the brewer.
Fill the water reservoir half way with vinegar and brew through. Once you've done that, mix up a 50% water/baking soda mix and brew that through. Compete the cleaning process by running just clean water through. Your coffee maker should be good as new!!
