Check the oil level in the crankcase if it just spills out the oil fill hole it fine
drain tank and drain float bowl and clean fuel tap make sure the carb is not green and blocked if so give it a good clean out make sure all jets are clean and clear- make sure fuel flow is good and carb connection and @ fuel needle valve / seat
make sure has spark
make sure muffler has no mason bees blocking muffler
give it a try
cheers pauly46
