It is possible to replace the connector but might be hard to find the exact match. Maybe consider going to Fry's or a local electronic hobby store and replace both sides of the connector. You might even be able to find one that does a better job at moisture sealing...maybe an auto parts store that has replacement connectors for the engine compartment.
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
SOURCE: How do I replace refrigerator
http://store.4appliancerepairparts.com/servlet/-strse-6795/16009-621038-751228-7516450/Detail
These switches snap into place. Carefully remove them by releasing one side so the panel is not damaged. The above URL will have a picture of a similar switch to the one in question.
SubZero 590 ice maker was not making ice. The flat connector that plugs in to the ice maker was corroded due to water dripping down the wire into the connection. A standard ice maker harness connector will work, the flat plug must be cut off of the harness and hard wired to the wiring going to the existing flat plug. The plug can be ordered online for $20 or less.
