The wiring diagram is under your motor hood in an envelope. Also look at the other end of the harness - the wires are in the same sequence. Just be sure to get all the insulation out of the connector before trying to reinsert the wire. Must insert wire with insulation on it. These are the red connectors I am talking about.
Please see attached diagram direct from Reebok POWER IN SOCKET WIRING. OS11301 Active Treadmill ON/OFF SWITCH GREY. GOES TO CONSOLE RESET BUTTON WHITE RED RED POWER IN SOCKET GREEN/ YELLOW GOES TO BOTTOM SCREW WHITE. GOES TO MCB **PLEASE NOTE** There will also be a further 2 wires that are not connected to the switch. These will be located in the upright arm, one will come down the arm and the other up it. These will connect to each other and form the power to the computer. One will have a male connection and the other a female.
These wires will usually be coloured white or one white and one blue.
