Pentax Optio S4 Digital Camera Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works perfectly well. Help me!
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Pentax Master 102,366 Answers
  • Posted on Jan 17, 2011
Pentax Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442339
Points
622693
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 05, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4746
Points
Hi, have this camera and still use it, The camera only takes SD cards and Not SDHC, it will use SD cards up to 4 GB but the camera format the card DOWN to 1GB and will work OK, If you format the card back up to 4GB in Windows and put it in the camera and turn it on you you will see that you can take over 1000 pic's but it will fail to save you first picture saying format error, and formatting the card again in the camera again will but it back to 1GB again, I use 1GB 2GB and 4GB without any problems, and you can still get 4GB SD cards on the net. so it's realy on a 1GB card camera hope this helps.
2helpful
I have purchased a 4GB SD-HC memory caard for my pentax optio s6. when istalled the card, the screen was turned on ok, but could not perform any function. Few minutes later a "memory card error"...
The Optio S6 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to use SD cards, 2GB and smaller.
Jan 13, 2011 • Cameras
1helpful
What card reader do i need for a pentax optio in windows seven
It depens what typ of memory do you use, Sd or MMC card. SD is the most common card and almost every multiple card reader can read it.
Check what type of memory card do you use in your camera and according to that by/borrow memory card reader.
3helpful
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
4helpful
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
5helpful
3answers
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
1helpful
1helpful
2answers
2helpful
2answers
Memory card
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
2answers
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
USB Connection problem Optio S4
have you turned the camera ON after connecting the cables? Next, does this USB port on the computer work with other USB devices such as memory sticks? My O555 has a USB socket that feels really "fragile" and I fear I will damage the socket with improper insertion (alignment seems touchy). I bought an external USB card reader and am really happy with that. You don't use up battery power transferring your files. Much better solution, IMO.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
