Heating & Cooling Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CODE ERROR E.EE - Fujitsu Heating & Cooling
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Jan 15, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
952994
Points
6173
When EE:EE is displayed on remote control , press "Energy Save" &
"Zone Control" buttons simultaneously for longer than 3 secs. The error
code will then be displayed on the LCD.Thanks.
Midea refrigerator beeping and giving an EE code, what can I do?
Still under Warranty then?
EE - There is a problem with the sensor terminals of the ice maker or the sensor circuit.
https://www.google.com/search?q=Midea+refrigerator+beeping+and+giving+an+EE+code
What is error code EE?
What machine are you getting this error code on? Because the EE code does mean an error but a different error on different things. So if you can tell me what are you receiving that on I can help you a little better.
EE Fault code means
make model (what it is) is needed for all questions, or we have to guess!
The EE error code indicates an error on the main control board. This error code is usually fixed by unplugging the washer for 10 minutes to clear any memory errors on the control board.May 3, 2017
LG Front Load Washer EE Error Code - How To Repair?
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
1helpful
Error code EE or E
Check your user manual, there should be a section on error codes. Most often E or EE errors are leaking cuff or improper use.
2answers
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
6helpful
3answers
Eee code
error code 01 reset? indoor signal sensor
2helpful
2answers
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
2helpful
Error message
EE error code with the top of the E missing is due to a faulty Thermistor.
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
