Remove the carb bowl and see if theres any fuel in the bowl and whether theres water and/or rust mixed with the fuel. If there is no fuel in the bowl then you have a fuel starvation problem. Check to make sure that your fuel line is not kinked so as to restrict fuel flow and then remove the fuel line and place it in a jar and the turn the engine over to see if the fuel pump is pumping the fuel. If you are getting fuel then you will have to disassemble and clean the carb.
