This is also what the instructions said however, what you actually have to do is
1. Turn on the blue tooth headset
2. Press both volumes keys together so light flashes red/green
3. turn on phones blue tooth
4. Find device and select.
Thanks anywayThis is also what the instructions said however, what you actually have to do is
i am trying to pair my opticom bluetooth with my nokia phone.. i cant remember the passcode..can this be re-set ?i am trying to pair my opticom bluetooth with my nokia phone.. i cant remember the passcode..can this be re-set ?
Re: I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
Press and hold down the headset volume key in the centre. Hold it for about 5 sec. The led will now flash on/off in red. This is the pairing mode. Set your mobile phone to blue tooth discovery mode,until it finds the headset, key in the pass key, 0000. It should now work. You may need to set the phone to select the headset as an automatic connection so it connects whenever it is on and in range.
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
Thanks anyway
am trying to pair my opticom head set to my nokia n95 i cant remember the pass code does anyone no how to change this ?
