Samsung 931bf monitor the screen goes out with a blue transparent hue. All color washes out. seems to happen afer bin for awhile. Any way to correct it ?
    Genius:
  • 1,288 Answers
Not really, the screen is failing, repair will probably be more then the cost of a replacement monitor
Posted on Jan 15, 2011
SOURCE:
How to open case/shell of Samsung SynMaster 931BF???
You remove all the screws, stand, then useing the thin flat blade screw driver to crack open the case, starting at the bottom edge and work your way around, it is hard to tell you in words. Try Youtube also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 15, 2010 | Samsung SyncMaster 931BF LCD Monitor
How do you reset colors
Try going into on screen menu and and look for factory reset on screen menu. You may have VGA cable problem or it can also be the video card. Please try this monitor on anther PC to see if the problem goes away.
Apr 20, 2010 | Samsung SyncMaster 931BF LCD Monitor
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
I can't get my Samsung SyncMaster 931BF to come of of sleep mode?
I already post solution for this problem, click here to see the solution.
Dec 21, 2009 | Samsung SyncMaster 931BF LCD Monitor
How do we know if the monitor is bad versus the computer? screen i black with occassional flashing of some white writing on the screen
when a montior goes out, you'll notice 2 things, a reddish hue and then a slight humm then mabey a pop(backlight death)
the other is no picture but backlight :D
check your connector
(if your using CRT try vacuming the back off it Dust can cuase and Deugass if you never turn it off)
the computer's GPU can be cuasing the issue, one way to find out, stress test it, and trubbleshoot, you can do this in display options :D
some stress test software would be off the top my head... uhh sandra
hope this helped
Sep 04, 2009 | Samsung SyncMaster 931BF LCD Monitor
Monitor comes on momentarily then black...tried 2nd monitor same
I suggest you try another video card in your computer. This may be the culprit if the second monitor did the same thing as the first. If the different video card does the same thing, I would then suspect the motherboard.
May 31, 2009 | Samsung SyncMaster 931BF LCD Monitor
My monitor has a green hue that will not go away when I adjust the colors in the screen. The blue adjuster doesn't seem to do anything. When I use auto adjust, It looks amazing for about 5 seconds then...
If you have another PC try it on the monitor, see if the problem persist. I f it doesn't check your video card's control panel. Some configuration there, may be overriding your monitor's. If you have an nvidia based card run the "optimize my display wizard"
May 08, 2009 | AOpen F2715-8S Monitor
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
On-Screen Menu
You have to check keyboard and the cable which interconnect main board and keyboard it could be damaged.
Oct 25, 2007 | Samsung 931BF 17" LCD Monitor
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
