What is happening is the one with two black wires is connected to a three way circuit aslong as you connect one wire to top of switch and other to bottom youre ok dont try to change the wiring the circuit wont work just see one wire as white connect it as normal
It isn't a three way switch. It is a single pole switch. The two black wires are from two different wire runs. I discovered the reason for it. Would you like to know? The two runs are on different circuits. Yes it's true. It was suggested by my brother-in-law. I thought that couldn't be right because after I popped the breaker when trying to reconfigure the wiring I but a different switch on it and turn the power back on. All the electricity in the house was on except the lights that are controlled by that switch. However, when I went to the other breaker box sure enough their was one breaker that was tripped. As long as both breakers are on the lights work, but if one is off the light doesn't work.
thank you for updating me i made note of this type of switch for future refrences
did you reconnect the wiring to how it was before you put in other switch you will be able to replace the switch with the way ity was before
plz comment reply if you need more help
Thanks for the effort, but I fugured it out. I think many people didn't understand what I was talking about. I had to explain it two or three times to everyone I told about it. It isn't a three way switch. It is a single pole switch. The two black wires are from two seperate wire runs. Each one goes to the two overhead lights in the room. To make things more confusing, the reason that it didn't work after I (acidently) popped the breaker after I tried to re-wire the whole thing is because that one switch is on two different breakers. Again, I don't know how this works, but when I popped the breaker I popped two (I have two breaker boxes). I didn't know this so when I tripped the one back on it didn't work. When I discovered that there were two breakers in different locations that controlled the same switch I put everything back the way it was and tried a different switch. This time I flipped both breakers back on. It now works fine. A side note to that story. I didn't know about the second breaker because all the other electricity in the house was working. My brother-in-law acctually suggested that since there were two runs that it might have another breaker. Apparently the other breaker only does the light switch, but the one I knew of does the whole room. Weird? Yes. To code? I doubt it.
