NEC (VT75LP) Projector Lamp for VT470, VT67 Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an NEC VT470. The projector shut down after the lamp finished. When I replaced the lamp and pressed the start button, the projector does not come back on.
Anonymous
Level 2:
  • Expert 76 Answers
  • Posted on Aug 05, 2011
Anonymous
Expert
Level 2:
Answers
76
Questions
0
Helped
18966
Points
138
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual.
Good luck
5helpful
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
2helpful
Nec vt470 lamp does not come on. replace lamp, when turned on status light turns red and get 3 beeps. lamp does not come on.
If you replaced the lamp already, chances are the ballast is defective. When you power on the projector with the power button you should see a flicker of light in the lens, or an electrical sound. If you don't you ballast is bad.
30helpful
3answers
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Ballast Unit
Ballast is nothing but it is lamp power unit so here high voltage operating unit. While change the unit please check the voltage ratting and model. connector model and then replace.
Regards,
prakash
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
6helpful
3answers
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
6helpful
3answers
Status light blinking red
Lamp not working
I had the same questions and decided to push power on and hold the help button as soon as soon as the power light came on. 10 secs later and the light was working again! Try grabbing a different NEC projector's remote, maybe it will have a help button.
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
