SOURCE: replace waste toner container on lanier 6625
Can you verify the model number once again? If there are letters in the model number, that would help as well.
Is the copier black and white or color?
SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
SOURCE: I have a lanier lp-138c that is giving me a black
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Testimonial: "great advise worked well but the copier had many more problems...."
SOURCE: lanier 7320 error message c-41 can someone tell me whats wrong
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
