There are several components to check when your dishwasher refuses to drain water. You need to check your drain hose, your pump assembly, timer, motor and drain valve and/or solenoid.
Most of the time it is the drain hose that is responsible for such problem. To check the drain hose, please follow the steps below:
To replace the hose, please follow the steps below:
That should do the job for you. And if that does not do it, then it means the problem is from other components of the dishwasher.
Hope this information helped.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Hi
Hi
Hi
Hi
Hi
