Woke up the other morning and the tv wouldn't turn on with the satallite remote or manually. a red light was flashing at the on button. checked voltage, ok. checked internal fuse with an ohm meter, ok.
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV: 1 – Turn ON the TV you will be using with the XR11 remote. 2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red. 3 – Begin manual TV code search by entering 991 on the XR11 remote. 4 – The LED status light will flash Green 2 times. 5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes. 6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF. 7 – After your TV turns OFF press SETUP. 8 – The LED status light on your remote should flash Green 2 times. 9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed. Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
thank's david. i'll see about getting it done. ronnie
