Konica Minolta Bizhub c203 Copier Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just replaced my Imaging Unit for my Konica Minolta Bizhub C203 and it will not print. Need help.
Ty Schmidt
Level 2:
New Friend:
  • Konica Minolta Expert 118 Answers
  • Posted on Oct 16, 2011
Ty Schmidt
Level 2:
New Friend:
Answers
118
Questions
0
Helped
57512
Points
180
What image unit did you replace? is there any codes??? more info is needed
2answers
KM bizhub c 203 prints blank on yellow, I have tried replacing the y imaging unit, y laser unit, image transfer belt, all to no avail. How could it be fixed?
Have you tried the High Voltage board that supply the voltage to the print heads and ITB. could be the print head is fine biut not getting any power to fire the laser and write to the drum
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
http://www.biz.konicaminolta.com/download/driver.html
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C203&page=1
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
GuruAid.com
3answers
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
2answers
Error code c-255a
C255A: Magenta TCR sensor adjustment failure
1 Reinstall imaging unit
2 Change imaging unit
3 Change PRCB
The printer did not reset when we replaced the black toner AND the imaging unit
Hi this issue may be casued because when you replace the toner and imaging unit they must be new and not taken from another machine i am sure if you put a new out of the box toner and drum unit out of box it will work
2answers
Erreur c2558
C'est la vie .
As the Installation Manual and Imaging Unit replacement instructions mention, pay close attention to shaking the imaging units and properly to level the toner and also keeping the imaging unit level when installing it into the machine.
1helpful
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
2helpful
Minolta c203 service menu
They extended the life of the image unit. They did not reduce the amount color in the print. Once they extended the life, the image unit will go until its copy qualilty will become completly destroyed. You will have to replace the image unit, sooner or later.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
