this is found in the MAF sensor on all BMWs. if you are having a OBDII code that is mentioning this the MAF sensor is most likely having the issue, or rather the IAT sensor that is mounted inside of it.
High possibility the maf sensor needs dervicing or replace. you can clea it yourself with electrical spray cleaner CRC brand. It is located inside the intake duct in a metal section. Do not brush or rub to clean. Use the spray to thoroughly wash off the sensor, It is sensitive and expensive to replace so be nice to it.
The spray will dry fast so don't use compressed air and don't physically touch the unit. Good Luck, Ned
The ABS relay on the E36 316 compact is the red relay in the fuse box, which as u look under the bonnet is on the right hand side towards the back of the engine bay. If that is of any help to you?
