Sharp XR-10X Multimedia Projector Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i just replaced the Lamp on my Sharp XV-Z91 dlp multimedia projector, the projector turned on but before i could reset the lamp timer it went into standby mode. Now the Power and Lamp indicators are red and projector will not come out of Standby mode. Please help
  • ravi347 Jan 14, 2011
    i have tried the reset sequence mentioned in the Manual ( power on, input, undo, left, enter, right, power on) but it does nothing is there another way to hard reset the projector lamp timer. The lamp is out of warranty so i am ok to try anything before i take it to sharp. I am fairly technical so any instructions would be ok
Anonymous
Level 3:
  • Master 1,833 Answers
  • Posted on Jan 14, 2011
Anonymous
Master
Level 3:
Answers
1833
Questions
0
Helped
555261
Points
4774
I understand your problem. If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise.
check those first if everything ok
then may be the circuit have some problem, go to the nearest sharp authorize service center. or visit website
Rinoo Kumari
Level 2:
  • Sharp Expert 2,973 Answers
Rinoo Kumari
Sharp Expert
Level 2:
Answers
2973
Questions
0
Helped
642569
Points
712
Ravi,
I just read the manual for the projector. It clearly says that the lamp, if used for more than 2400 hours, will send the projector into standby mode. And then it should be taken to the nearest Sharp Service Center. Please do that. It means that the breakout from the standby mode is very technical and should be handled by trained technicians of Sharp.
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Hello i have a sharp projector model xv-z21000 my
mainboard is not work ,it need to be repaired
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
1helpful
I have a Sharp xv-z9000u projector. I recently replaced the lamp; however, I cannot turn the projector on. how do I reset the lamp timer?
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
How do you reset the lamp timer on a xvzw99u sharp lamp.
Hi
To reset the timer on Sharp XV-ZW99U--Hold adj down and vol - (minus) at the same time, while Turning the main power, located on side panel, ON. Hope this helps...
Daniel
1helpful
I have replaced the lamp on my sharp xr-10x L. I cannot get the bulb to turn on I have lights so there is power but the lamp is not on.
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
Just changed the lamp in our Sharp DLP Projector, lamp indicator
You don't mention whether the power light is on as well. IF you are seeing red lights for both power and lamp, there is a problem with the circuitry, beyond just the lamp. unfortunately this is very common. The unit will likely need a new ballast circuit.
4helpful
SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
How to reset the lamp usage for Sharpvision XV-Z1U
Press and hold VOL. DOWN and ADJ. DOWN (ARROW DOWN) while turning oh the main power switch.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
