I need a wahl replacement charger PCC as well!!! if anyone knows how to get on let me know because Wahl No Longer sells the clippers so they don't sell the charger now! that sucks wahl !! they should be able to sell you the charger when the charger goes bad like mine did ! it had a short in it and i accidently threw it away!!! now i don't know how to find a replacement charger?thanks
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
SOURCE: wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
SOURCE: I have a Wahl clipper Pro Series Rechargeable
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
SOURCE: I disassembled my Wahl 8552
How did you get it apart? I don't want to break the case and can't get it to release at the front of the unit.
