Maytag Ensignia MAV2757AWW Top Load Washer Logo
Posted on Jul 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine The washer will not fill up with water. The water runs and automatically drains out. It started doing this only on rinse, but now on wash also.
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Jul 13, 2008
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
897820
Points
3823
The number one cause of this is your drain hose is too far down in the stand pipe or too low beneath the tub the drain hase should loop above the tub and about 4 inches down in the stand pipe if not this will create a siphoning effect that will drain the water as it fills
Washer won't spin
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Avanti washer repair
Good Day,
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Won't drain and showing F 01
Good Day,
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
7helpful
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
