HI,
The FdL code is saying that the circuit board that runs the washer (CCU board) thinks there is something wrong with the door lock. Often times it's not the door lock but bad connections at the CCU. Whirlpool had some bad quality control with the CCU circuit boards and the end result was cold solder joints at the spade connectors and the relays (there's 5 relays on the CCU board) With this repair you need to remove the circuit board from the inside, top, back of the machine. Mark all the connections before you take them out then remove the entire plastic case with the circuit board inside. At this point you can resolder those points I spoke about or take the board to a good appliance repair shop along with this response and they should be able to help you out. Good luck.
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an
issue with the door lock when it is unable to lock/unlock. Please check the
door lock mechanism/door switch assembly and replace the part that has gone bad
so that the issue is resolved. Please get back to me if you have any other
questions.
Kevin
