First UNPLUG THE UNIT! If you have a volt meter does it have a feature on there to make noise? If so set it to that and test the two wires going to the heater if it makes noise its god if it doesn't then its your heater next check the thermostat attached to it same way if it beeps or chimes its good if not theres your problem next move up the heater to the top thermostat which is the high limit one test it same thing more than likely if the heater isn't bad here is your problem. If all that checks good check the next thermostat to the lower left located on the blower housing test the two red wires same thing again. If all test good you either have a bad timer or motor which there is a heater switch that kicks it on inside the motor. Which if its either of those two it will run you $125 and up on the part. But if any of the others don't check out okay get the model number off the dryer located on the inside door opening area and take that to your local appliance parts house along with the bad part. If there all okay time to call a qualified service technician to come out and check to see if its the timer or motor that is bad but hope this helps and good luck.
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
