Question about Leviton R01-PR180-1LI Decora 180 Degree PIR Motion Switch Ivory
I have a Leviton PR-180 Occupancy sensor light switch wired in a walk-in closet. The auto mode never seems to work properly. The light will randomly turn on throughout the day and night without any apparent motion. I've ruled out the HVAC air vent by turning off. I've heard to turn on in "on" mode for a min and then slide to auto mode...but still nothing. Just seems to be turning on randomly. Very frustrating.
SOURCE:
VtToolMan
  • 704 Answers
SOURCE: new Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
Posted on Aug 07, 2009
gotgeek2
  • 565 Answers
SOURCE: I have two Leviton Decora Motion Activated Light
Unfortunately you cannot use two PR180-1LA's for what you want to do. :-( There is only one correct installation:
One PR180-1LA needs to be installed at the switch box which contains the cable that goes to the light (load). That is a must. One then installs a regular 3-way switch at the switch box which contains the cable with the hot from the breaker (line or source).
If you reverse the sensor location you will need 4 wires between the switches, which is not usual practice, as the bare grounding wire is not permitted to carry current per National Electric Code rules.
If you want a sensor at both locations you need to install a IPP15-1L at the switch box that has the cable going to the light (load). One must then install a IPP0R-1L at the switch box that has the cable with hot from the breaker (line or source).
Posted on Feb 19, 2010
jse2005
  • 103 Answers
SOURCE: I am trying to replace a two wire light
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Posted on Jun 28, 2010
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Posted on Nov 23, 2010
gotgeek2
  • 565 Answers
SOURCE: I just installed a Leviton
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Posted on Dec 22, 2010
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit.
I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
Apr 16, 2016 | Leviton Electrical Supplies
Motion sensor light
Just ignore the fact the new device does not have white neutral. While old device has neutral
Difference: The new device is rated for incandescent only, while the old device was rated all type of lights including cfl etc.
Copy following link for wiring illustrations
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
Check manual for product rating. You might want to return device and buy one with white neutral wire so it will work with your application.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 10, 2013 | Leviton R01-PR180-1LI Decora 180 Degree...
I purchased the pr 180 photo electric switch from home depot.there are not any wiring instructions enclosed.I have two black wires and a ground in the wall. there is a green ( ground ) black,red, & a...
Leviton PR180 is a single-pole or 3-way motion activated light switch.
Resources:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=452283§ion=10892&minisite=10026
The green connects to bare ground wire.
The yellow-red is not used EXCEPT to replace 3-way switch. Cap off yellow-red wire when wiring single-pole.
Your single pole switch has two black wires.
One black wire is Hot from breaker, and the other black wire goes to Load.
Turn power on, and test each black wire to bare copper wire. Tester lights up on Hot wire.
Hot wire connects to PR180 black wire.
Load wire connects to RR180 red wire
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Leviton ODS10-ID Decora Wall Switch...
I'm trying to replace a switch outlet combo with a leviton pr180 with occupancy sensor...it has black, red, green, and yellow red wires. The wiring in the wall is one black and white and ground for the...
In addition to the black, red, green, and yellow/red wires on the switch, there should also be a white wire or terminal marked WH. The black wire on the switch connects to the incoming black wire (line in or hot) inside the switch box. The red wire on the switch connects to the outgoing black wire (to the load) inside the switch box. The green connects to the bare wires inside the switch box. The yellow/red is not used in a single pole application such as yours. The two white wires inside the switch box are twisted together and _also_ connected to the WH terminal (or white wire) on the switch.
Jun 29, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
Where can a get information how to install a automatically turn light swicht leviton model occupancy sensor m,odel
What's the problem? You can get instructions at leviton website but also suggest you read competing products manuals to build perspective. These are difficult to install in 3 way wiring situations. In 3-way they only seem to work well when wired to load not line side. In 3 way I suggest you wire in 2. There is a certain way of doing this. I just looked at instructions for Leviton's competition.
Jan 09, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
I installed the PR180 switch in my garage with a 4ft dual t-8 flourescents bulbs. When the motion sensor timer turns the light off the flourescent bulbs stay slightly lit, as if it were on a dimmer...
There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
What you need is a motion switch that is rated for flourescent lights, such as this :-( :
http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
Nov 28, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I have installed (or tried to) three different Leviton PR 180s in my front hall. All operated the 23 watt fluorescent bulb in the fixture satisfactorily, but were not affected by the ambient light; that...
The Leviton PR180 is a motion detector, or occupancy detector.
It senses infrared heat from a person's body.
I am looking at the manual from Leviton.
Maybe this will help:
There is a small adjustment screw under the wallplate where you can adjust light sensitivity.
Use fingernail or small screwdriver.
Turn control towards the "-" sign and lights will turn on in 'less lighting conditions'
I will be here for a few more hours.
Add a comment and I will help further is needed
Nov 05, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I have installed a PR 180 at the top of the basement stars to turn on the light when someone enters, and a normal 3 way switch at the bottom. The idea was the lights come on when you step into the...
While there are many ways to wire 3-way switches, the most common way is to bring a 2-wire/with ground HOT and neutral cable (from circuit breaker or source) into one switch box and a 2-wire/with ground LOAD cable (to light) into the other switch box. Then a 3-wire/with ground cable is ran between both switch boxes.
The PR 180 _must_ be installed at the switch box the has the cable that goes to the LOAD. I suspect that you have the PR 180 installed in the switch box that contains the HOT feed.
Unfortunately, the solution is to install the PR 180 at the downstairs location and have the normal 3-way switch at the top.
Another solution would be to install a Leviton 1PP15-1L at the switch box that has the HOT feed and a Leviton 1PP0R-1L at the switch box the has the LOAD cable. This, of course will result in a sensor at each location.
Aug 20, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
LEVITON IPPP10 WIRING QUESTIONS
White can never be connected to power. Look at the paper provided with device. It will tell you the incoming power wire and the load wire. These must be correct.
Jul 29, 2009 | Leviton Manual-On Occupancy Sensor -...
Leviton R01-PR180-1LI Decora 180 Degree PIR Motion Switch Ivory Logo
264 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
