You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
SOURCE: I have had to change my lap top and the CD for my
You can download the USB driver from Fuji support website by clicking this link
On the page which opens, click on the 'Download Now' button to download the driver. (Finepix S602 is given in the Products supported list for this driver)
Alternately, you can download pictures from your camera to your laptop by using a memory card reader
You can use your laptop's built-in memory card reader, if it has one, or you can purchase an external memory card reader as shown in the attached image.
To do this, kindly remove the memory card from the camera and insert it into a card reader. If you are using an external memory card reader, connect it to the USB port of your laptop.
Now, the memory card will be shown as a "Removable disk" in "My Computer". You can browse the images and copy the images to your computer.
This method is very quick as compared to connecting the camera to the computer, and also saves the camera's battery.
Hope this solves your problem. Thanks for using FixYa.
SOURCE: I have a Fuji FinePix
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
