Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
check that the abs sensor is properly connected, if it is, then try disconnecting the battery for about 5 minutes and depress the brake pedal and turn ignition key on and off. Then reconnect the battery.
If that doesn't work erase the abs code with the scanner that should fix your problem.
Hi, This could be for a couple of reasons depending on what exactly happens. I will assume that by you saying that you have charged it the orange light came on and stayed on until it was fully charged.
When you say it doesnt want to turn on does that mean the green light comes on for a brief moment (1-2secs) and then turns off again or is there no signs of life at all?
If the green light comes on for 1-2secs then one of the screens should flash, if one does then the other one will need to be either reconnected if its become loose or replaced. For a guide on how to change your top or bottom screen click on my name then scroll down to tips and tricks, select view all to see my full list.
If the green light doesnt come on at all then the chances are you have blown the fuse. Again if you need a guide on changing the fuse click on my name and then scroll down to tips and trick, select view all to see my full list.
I hope this helps, if you have any questions feel free to message me.
