Microsoft Xbox 360 Elite Console Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i find my ip address. to get on xboxlive
Anonymous
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on Oct 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
3720
Points
97
Hello friend, you can find your ip address by visiting this site IP-Details.com .It provides your location, country etc., details..
Jose M. Gonzalez
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on Jan 13, 2011
Jose M. Gonzalez
Expert
Level 2:
New Friend:
Answers
104
Questions
0
Helped
17373
Points
324
If all you need is your IP address, you can go here and it will tell you what's your IP.
The router was open two days ago when I was playing the xboxlive suddenly the next day it changed to strict how can I change it back to open so I can play with my friends online?
Basically what happend is NAT closed instead of being open NAT. You have to log in to the router ip address in your web browser and set it to open nat. You get your router ip address by going to the command prompt and typing ipconfig. You can google this procedure or consult Netgear as they can walk you through it easily. Youtube has videos on how to open Nat on many different brand of routers. Now you know the problem and what the answer is please rate and comment!!! Thanks.
I cannot connect my xboxlive to the router
Hi Friend,
Please follow te steps:
1. Start>Run.type cmd and hit enter
2. type ipconfig/all and hit enter. Note down the IP address of Defaul gateway
3.Type the default gateway in the web browser and hit enter
4.enter the router username and password. Default password is admin with no username.
5. In the router setup page click Applications and Gaming and then click DMZ
6.Select Enable
7.Let the Source IP address be selected as Any IP address
8.In the destination IP address put the IP address of the xbox
Click save settings
Regards
Chiranjeet
1helpful
2answers
When i try to get my ip password it shows up as
Is your X-box wireless ? If it is wireless and you are trying to connect to the wireless network, then make sure that you have all the wireless settings correct. IF the network is secured then make sure that you have the correct network key.
You tried manual IP address. The manual IP address should be in the range of the router IP address.
Click Here
for more information about the router and x-box
Can't connect to xbox 360
If your XBOX can't connect to XBOX Live, then here is the trouble shooting procedure:
Your ISP (or router) might be blocking ICMP. From a PC connected to the router, open a command prompt and type
"ping www.xboxlive.co.uk" you should get the following
Pinging www.xboxlive.co.uk [213.171.195.53] with 32 bytes of data:
Reply from 213.171.195.53: bytes=32 time=45ms TTL=246
If you don't get the reply then check the firewall settings on your router for ICMP. If this is enabled, run the following command on the PC
tracert 213.171.195.53
You'll get a line of IP addresses, and if the trace doesn't complete, it will tell you where in the network ICMP is being blocked.
(These are the addresses for the UK, other countries will be similar)
Port setting to allow my xbox to run games
Hello djand2kidz,
Inorder to resolve this we need to open application ports for the Xboxconnection. This problem can be resolve by any of the following:
  1. Opening port Numbers TCP 88, TCP/UDP 3074
  2. Lowering MTU size and Disabling SPI
  3. Enabling UPnP
  4. Enabling DMZ
  5. Upgrading the firmware of the router.
  6. Set NAT filtering to open (Only available on WGR614v6, v7, and v8)
Here are theoptions on how your Xbox connected to the internet. Opening Port Numbers TCP 88, TCP/UDP 3074:
1. Make sure that Xbox has valid IPaddress of the same range of the Netgear router.
2.
Assign static IP address on Xbox.The following values should be used while assigning static IP address on theXbox.
IP Address: 192.168.1.x (e.g. 192.168.1.200)
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
Note: Here ‘x’ can be any uniquenumber from 2 to 254 depending upon the IP address assigned to remainingcomputers in your network.
3. Oncestatic IP address is assigned, the requisite port numbers can be open using thesteps below.
a. Open the browser(Internet Explorer or Netscape) and type the IP address of the Router(192.168.1.1) in the address bar.
b. It will prompt youto Login into the Router (Username = “admin” & Password = “password”).
c. Select "Port Forwarding" under "Advance"
d. Select "Port Forwading" under "Service Type"
e. Click on "Add Custom Service"
f. Prepare the following Service for opening port 88 TCP/UDP.
g. Clcik on "APPLY" after creating Xbox_1
h. Again click on ‘Add Custom service and thenenter the values to open port number TCP/UDP 3074.
i. Click on ‘Apply’ after creating Service Xbox_2.
j. OnceXbox_1 and Xbox_2 services are created you will there entries under ‘PortForwarding/Port Triggering Option.
2answers
Xbox live hookup
im having trouble with putting all of my information into the thing to set up and account so i can have xboxlive!
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
