Question about Kenmore 34721 Upright Vacuum
Motor varies in speed and smells light flickers
  • 694 Answers
It sounds like the motor's going bad. I suggest replacing the motor or the vacuum, depending on the condition of the rest of the vacuum, and how much the service center charges for a new motor and service.
If it's an older vacuum, there are probably additional items showing wear and tear. This would make it more feasible to purchase a new vacuum.
Posted on Jan 13, 2011
SOURCE:
Green light flickering!
only use a genuine kirby belt. not copys that are sold on the web. it sounds like one of the end bearings is jammed with human hairs, remove end cap and cut out with a stanly blade
May 25, 2017 | Kirby Ultimate G Bagged Upright Vacuum
GREEN LIGHT AND MOTOR
The green light is an indicator that your brush is rolling smoothly. If it starts to flicker and you smell something that smells like rubber burning you need to do a couple things; one is remove the roller and clean off all of the hair, string, etc. Next you want to replace your belt. Just because the roller isn't turning doesn't mean the motor and the belt aren't either. If your roller gets jammed your belt will continue to spin and it will eventually wear down in one spot and break. Replace the belt, clean the roller and your should be fine.
Apr 26, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kirby heritage 2 motor runs slow then speeds up with burning smell.
Replace your belt and clean your roller brush.
Mar 25, 2013 | Kirby Vacuums
Vacuum motor hunting (varying speeds) eventually stopping
Hi Colin. This does not sound good. Sebo's are great machines. I think the motor brushes are going. If so, they can be repaired and the Sebo is worth fixing. Let me know please. Chris
Feb 09, 2011 | Sebo Vacuums
I replaced the belt as I have done before on Self-Propelled Vision. When turned on it is very loud and left on too long will smoke and you can smell the belt deteriorating. I do not feel this is a belt...
The best way to check if the motor is burning or not is to go back into the unit and take the belt off of the motor shaft. If the unit does the same thing and burns or even if the lights flicker when the unit is on, then it is definitely the motor.
Usually the burning smell associated with this is like a burnt match or burnt wood.
good luck.
Nov 19, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
My Miele Solution HEPA 5000 vacuum cleanr gives off a burning smell but will continue to run with a varying motor tone. I have not run it for more than a minute like this. I have reviewed responses to...
Check both the bag and the HEPA filter behind the bag, torwards the motor. The HEPA filter could be clogged. Love these units but it takes clear attention to multiple filters.
Mar 06, 2018 | Miele S318 Bagged Canister Vacuum
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
Hello, I have a problem with my Eureka Powerline bagged upright vacuum. It has a 12 amp motor and is model #4352, Type D. It was probably bought new in 1998. My problem is, while vacuuming today the motor...
it sounds like a rubber sealing in the motor has come loose and is being constantly rubbed against the walls of the motor with would cause the smell and loss of motor speed caused by the fricton of rubber against the rod so if you can get to the motor try to open it and see if you can get it if not take it to a small engine repair service hope this was helpful:)
Nov 16, 2009 | Vacuums
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 34721 Upright Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
