Question about Husqvarna Garden
I just recieved a husqvarna 128LD trimmer. What brands of attachments are out there for this unit? I am specifically searching for pole saw and hedge trimming attatchments. Thanks!
    New Friend:
Hi, they can be found on amazon, here: Amazon com husqvarna 128LD trimmer parts Hope this was helpful. cheers
Posted on Dec 03, 2014
The Husqvarna 128LD trimmer does accept attachments; however it does not accept Husqvarna attachments.
The 128LD is designed to accept only lower consumer quality "Expand-It", "EZ Link", and "TrimmerPlus" attachments; which includes those from Ryobi, Toro, Troy-Bilt, Craftsman, John Deere, Homelite, and Poulan. It uses a different connector head than the Husqvarna attachments. Husqvarna currently does not even list it on their website. Husqvarna's only information on the 128LD is buried at http://husqvarna2.custhelp.com/app/answers/detail/a_id/603 .
Having a more reliable Husqvarna power head is great, however Husqvarna and Lowes should be upfront that the 128LD is not supported by Husqvarna's higher grade attachments.The 128LDX; which does accept Husqvarna attachments and is available through dealer's, is the same price as the LD.
Posted on Apr 27, 2011
  • Bobba Lou Apr 27, 2011
    I checked, thanks for the correct info.
    New Friend:
Specs for the 128LD are located here:
http://www.husqvarna.com/us/products/trimmers/128ld/
TrimmerPlus attachments work just fine with the 128LD detachable shaft.
Posted on Aug 25, 2012
  • Husqvarna Master
  • 2,239 Answers
I think there may be a miss understaning here, the 125LD is a split shaft machine and there are a number of attachments for it, there are two grades, pro attachments from the 327LD machine short hedge trimmer, long hedge trimmer,brush, pole saw,and rotivator, from the consumer side there is a hedge trimmer,pole saw,blower,edger,and cultivator, all are available from any Husqvarna dealership, the pro attachments are obviously much more expensive.
Posted on Jan 17, 2011
    Unfortunately, this answer is incorrect; the 128LD is a convertible trimmer.
    Top Expert:
  • 6,289 Answers
Https://www.husqvarna.com/us/
Posted on Oct 19, 2018
    Scholar:
  • 127 Answers
The 128LD is not a convertable trimmer. It does not have various attachments like, blowers, pole trimmers etc available. Husqvarna only offers replacement trimmer heads and blades as accessories for this model.
Posted on Jan 13, 2011
    The Husqvarna 128LD trimmer is a convertible trimmer, but only uses Ryobi, Toro, Troy-Bilt, Craftsman, John Deere, Homelite, or Poulan "Expand-It", "EZ Link", or "TrimmerPlus" attachments.
    Unfortunately, it does not have the same connector as that used for Husqvarna attachments and cannot use them.
  • Steven Gray
    Steven Gray Oct 19, 2018
    I was told at the dealer that the 128ld was made to sell at lowes and home dept stores and to take the same attachments as the other brands that they sell
    the 128ldx only takes the Husqvarna brand of attachments
    if your doing heavy work and need best attachments get the 128ldx but for a homeowner the 128ld will save you 40-50% on attachments
SOURCE:
Dethatcher
Sorry they do not make a dethatcher for them not enough power .
Jun 27, 2015 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Husqvarna 128Ld wont run after 30 seconds
put the correct spark plug in it and no a CJ8 isnt the right plug !!!
Dec 21, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna 128LD Starter Recoil Issue
Here is the complete Illustrated Parts List. It has exploded views of the whole strimmer.
Jul 20, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna Trimmer 128LD starter card will not retract
Check the recoil spring in the starter housing, sometimes the rope rotor can jump out the hook on the spring.
Oct 22, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
My husqvarna 128ld won't start
Do you have compression, good spark and is fuel getting into the cylinder.?
Oct 21, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
Jun 16, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
How do I install a brush cutter on my 128LD trimmer?
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
May 12, 2011 | Husqvarna Garden
Husqvarna SRM 225 It starts fine but dies once you give it gas.
I was having the same issue with my 128LD string trimmer. I called a local Husqvarna service dealer and they told me the issue was a result of the ethanol in the gas. They suggested I find ethanol-free gas (aka 'Pure Gas') and try it. [http://www.pure-gas.org/ was the best resource I could find for this]
After disposing of my old gas and filling the trimmer with premium grade, ethanol-free gas (with Husqvarna brand oil mix) and applying 3 squirts of carburetor cleaner to the carb, it runs radically better.
I hope that helps you too. I know how frustrating that can be.
Jul 21, 2010 | Husqvarna 225cc Hedge Trimmer 22" Cut HVH...
Garden Logo
19,872 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
