SOURCE: vibration shudder at around 30km
Hey Pontiac,
There are two things, firstly get your front wheel rims put on a lathe machine to check for distortion, if not, then get the wheels balanced on a digital tyre balancer.
let me know if this works
SOURCE: removal of gearbox cv joint
It just pulls out of the geat box, it has a internal snap ring, they can really bwe a bear if they're being pulled for the first time.
SOURCE: 93 Subaru Legacy front suspension problem after CV joint replaced
the air bag is not ok, this is exactly what they do when they have a leak, these air bags are shot at about 100,000 miles, they start to leak at the creases, u will see cracks there.
SOURCE: knock on left front suspension over bumps and rough roads
Have the sway-bar end-links replaced. They will thunk and rattle over washboard or severe bumps, but will not when wheels are turned and sway-bar is loaded.Fairly cheap and easy repair, no alignment needed.
SOURCE: replacing CV Joints
Yes you can remove the drive shaft by unbolting the bottom ball joint,then removing the nut that holds the shaft in the hub I would'nt recommend trying to replace just the CV joint as this can be a very complicated procedure involving specialized tools and more than just general mechanical skill,this isn't true of all,as some CV's come apart fairly easily.If the joint is bad you should probably just replace the axle.Remember to match mark any adjustable parts you may have to disassemble,and when you reassemble make sure to check the splines of the shaft and the drive hub,remove any foreign material and carefully file or sand any burs or scratches,any of these can cause the spline to bind on reassembly and possibly cause irreparable damage to one or both parts.Good luck hope this helps.
