Hi, suddenly i got the error U052 ... incorrect print head installed. It printed fine last time except blue was stripey but cartridge is full. I've had no paper jam or other probs.
The error U051 / U052 indicates that a communication issue with the print head. This can be caused either by the print head not being installed or print head not working properly. The issue U051/U052 canon printer can be fixed easily.
·Reset the print head
·Restart the printer
·Check ink cartridge
Read continue the steps to fix the U051/U052 error code in canon printer.
The U052 printer Error occurs in two different scenarios. The First one is when the print head is not installed properly on the canon printer. And the second Scenario is When the print head is installed well but is not working properly.
Follow the steps to fix the U052 printer error code. Need any type of help contact printer experts through Free Live chat.
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Hello.
Sometimes this is caused by the chip on the black cartridge. I know it sounds unusual but this chip is called the "master" and it identifies the series of cartridges and head to a table built into the printer. if a error is detected it can cause the message you are receiving.
If you have already removed the head, checked the contacts and replaced the cartridges, then try this link below. it may help re-set the printer.
http://www.fixya.com/support/r9017204-resetting_ink_waste_absorber_error
I hope this helps
Regards
GM
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
