SOURCE: HP Pavilion DV9535nr -- problem
When you first started the installation there would have been a pause in the set up offering you to press F6 and to install sata/scsi support using the driver supplied with the drive.
SOURCE: installing windows xp on hp pavilion dv 6516 tx
I'm not sure solution #1 is very explanatory, so....
IF you want to install XP on your computer, Windows XP will load most of the drivers you need automatically.
For the drivers that are specific to your HP pavilion
you will be able to download device drivers from HP website
or, request a driver CD
When XP is installed [assuming you or someone can do that]
you can:
Go to the 'My Computer' icon [right-click]
Choose:
Here you will have a list of all your hardware
If you have any drivers that need to be installed, there should be
a yellow (?) question mark by the name of the hardware
Most devices/hardware will be handled by XP SP2
The default drivers will be loaded automatically
For example, your keyboard:
Above you see the window that opens if I double-click on
the 'Keyboard' icon.
For XP to function, you only have to worry about the ones
with the yellow (?) question mark
Or, if you want to add a specific driver, like a Video or Sound driver, but you don't see a yellow (?) question mark
you can still install/update the driver at the 'driver' tab
[second tab in the picture above]
If you need more specific help I can do that too
SOURCE: XP Drivers for HP Pavilion DV 6516 tx Laptop
I too had a similar problem. I got VMware (virtual machine)installed and XP installed inside that.
SOURCE: How to install driver in preinstalled vista in notebook OR download xp driver
how to install xp in my notebook dv2519tu...
SOURCE: problem in installing xp drivers in hp pavillion 6602au notebook
if u want to get rid of this i can really help u out with the same but u will have to pay for it,only sound drivers are missing;i have discovered all the drivers needed for the hp pavilion dv6602 to work freely..
contact 9970382492
Dj Aks
