We experienced the same issues on 3 different MobiGo units. New games would work and then at some point stop being recognized or they would be recognized, but the unit would turn off when you selected the cartridge.
Fix: Use a Q-Tip to clean the contacts of the cartridge. The Q-Tip was too thick to insert so I cut it in half and the stiff cardboard shaft fits perfectly. Rub back and forth across the contacts on both sides. You will notice a black smudge left on the Q-Tip.
If that didn't work then I went to the next level. I could not figure out the term to describe this but to say that you might have to fog up the cartridge contacts asyou would do to clean your glasses. Once the contacts are moist from your breath clean them with the Q-Tip shaft. This worked on several cartridges. You should probably use rubbing alcohol instead of your breath since these are electronic components.
Hi Julie, my granddaughter's mobigo is doing the same thing...have you figured out the problem? I don't know what to do either.Mary
