I've a glass CookTop. One of the burner element (double) no more works. The cricuit breaker trips again and again. Is there some fuse that i can locate to fix this problem.
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Two of the burners are putting out decreasing heat
I have the same problem. Once the cook top is removed from the counter, how do you remove the glass from the unit?
I have similar problems with my dual element. It 1st started with the heat control knob tighten up and was difficult to adjust. Then when the stove was off, the indicator light remained on - but it wasn't. It appeared to be shorting out. After sometime all four "element on" lights remained on even though there was no heat. WOULD APPRECIATE ANY SUGGESTIONS TO HELP ME FIX THIS PROBLEM.
I would just like to find out if there is some sort of reset switch.
