Coffee Makers & Espresso Machines Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many scoops of coffee and water do you use for 36cups?
Anonymous
Level 2:
New Friend:
  • Expert 92 Answers
  • Posted on Jan 13, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
92
Questions
0
Helped
50554
Points
244
All depends on how you like your coffee, And the size of cups you are using.
The standard is: 64oz. of water and 2oz to 3oz of coffee for 12 cups, That is about 5 to 6oz.of coffee per cup.
If you want a strong cup of coffee use 1.5 gal. of water and 9oz of coffee for 36 cups. If NOT use more water and less coffee.
REMEMBER, Don't let the coffee sit in your coffee brewer for long time.
Do you sell coffee scoops?
Just use a regular tablespoon to measure coffee.
I usually use one tablespoon per 6 ounces water.
Because I like my coffee a little stronger, I
usually add one extra for the pot, no matter
how many cups I make. Works for me.
1helpful
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Can u please tell me how many desert scoops should I put into the filter / to how much water? I've been puting in about a litre of water and 6 scoops of coffee but it seems very weak!
Hello. This will be a trial and error situation. Increase the scoops of coffee to 7 and see how it tastes. If it is still a wee bit weak at 7, jump it up to 8. Joe
4 thmbs up please. Thank you.
3helpful
How many scoops per cup?
Don't follow the machine directions for the coffee, follow the coffee
for amount per cup. Each coffee can call for a different amount.
Once you make a few pots with the same brand you will know if you want a stronger blend or weaker blend.
Start with 1 tablespoon per cup 6 oz of water.
2answers
How many scoops of coffee for 36 cups?
the traditional wisdom is one scoop per cup and one for the pot
1helpful
Sending preground shot through with no water, the shot of coffee just falls through to the dump. The machine goes through the process like its going to make the coffee but no coffee. No problem with the...
Hi
If you use the scoop that came with the machine make sure that you use 1 level scoop and no more. Slightly rounded scoop will also work but NOT A FULL SCOOP.
How to make coffee with the toastess coffee maker
If the scoop is 1 tablespoon, use two scoops of ground coffee for every six ounces of water you are brewing.
If the scoop is 2 tablespoons, use one scoop per six ounces.
Also be sure your grind is proper for the type of filter you are using.
Measurements
the size that comes with the coffee.
2answers
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Top Faberware Coffee Makers & Espresso Machines Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
john h
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
