Not using High Efficiency (HE) detergent.
Too much detergent was added.
Using too much 2X or 3X HE detergent
Solutions for over-sudsing:
- Always use HE detergent in an HE washer. It is formulated to be a low-sudsing detergent and made especially for HE washers.
- Be sure to use the correct amount of detergent. HE washers require only a small amount of detergent. Note: This amount may need to be adjusted for water hardness, load size, and soil level.
- If using a 2X or 3X concentrated HE detergent, much less detergent is needed. If suds are seen, reduce the amount used.
- If using a water softener, less detergent.
- Make sure both Hot to Cold water hoses are connected properly at the faucets and at the washer.
