If the freezer is not cooling, then problem
relates to compressor.but still wait more 12 hours and see if it starts
cooling.Basically it takes approx 24 hours to regain its cooling, once its
unplugged for few hours and then plugged in.---------- So once again check
after another 12 hours and see if you notice cooling.But if there is no cooling
then yes its compressor issue.-----------
If freezer will not start cooling, then fridge
will also not start.------------
Click this link below and get more
details:---------
http://technoanswers.blogspot.com/2011/08/freezer-taking-too-long-to-cool-or.html
This will help, thanks.Helpmech
Try manual defrost reset
procedure: ----
First unplug the unit
from main power outlet. Then empty whole unit completely. Then keep both the
doors open. Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced. you
can get the required parts from online sites like:---
www.repairclinic.com or
from searspartsdirect online site.---------
If it's again building up ice
that means the unit is not defrosting. It's starting the cooling procedure, and
then while defrosting, it's not working. The procedure of this unit
is as follows: --- The compressor starts then it cools the freezer section.
When the freezer reaches its cooling level the defrost cycle starts functioning.
In this cycle the fan in the freezer section starts running and the cool air in
the freezer section is passed to the fridge section and the fridge section
gets cold. The air from freezer to refrigerator passes from the section, in
that section the damper is located.
This will help.Thanks.Helpmech.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
