Question about Motorola Mobility H500 Wireless Headset
I have recently purchased Motorolla Bluetooth head set (H500). After charging the same, I am trying to pair it with my cell phone (Sprint Samsung M330), its not discoverable. The bluetooth on the phone is on and its detecting other devices. Please let me know which setting I am missing.
  • Motorola Mob... Master
  • 10,528 Answers
Is the headset in the discover mode? Usually its a 2 button press and hold until the led blinks or changes color.
Posted on Feb 15, 2018
5 Suggested Answers
SOURCE:
SOURCE: bluetooth
great!! very extremely helpfult
Posted on Jan 15, 2008
  • 6 Answers
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
Posted on Mar 14, 2009
solasknows
  • 199 Answers
SOURCE: How do you set the H500 Bluetooth device in
press the talk button for 11 seconds see how the light start blinking
Posted on Jul 20, 2009
  • 6705 Answers
SOURCE: My Motorola Elite Flip Bluetooth will not pair with my new Samsung s5. Can you help me
page 19 and 20 of the manual tell you what to do if the flip won't pair. https://motorola-global-portal.custhelp.com/ci/fattach/get/634666/1370266396/redirect/1/filename/Elite_Flip_GSG_68017335001A.pdf
Posted on Jan 13, 2015
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
May 23, 2010 | Motorola Mobility H500 Wireless Headset
How to sync my bluetooth?
Hold the power button down approx.
6 seconds until the blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Go to your cell phone after you've done the above directions and:
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H500.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
I hope this helps anyone else who's having a problem pairing their Motorola H500 Bluetooth headset :)!!! I just got mine to work w/ the same info!!!
-Rebecca :)
Dec 29, 2009 | Motorola Mobility H500 Wireless Headset
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
My samsung a737 doesnt see motorolla h500 bluetooth
If the bluetooth you are connecting to is a Motorola 500, the trick was to HOLD the "on" button while the phone was searching for the device. Turn on the Motorola device and keep holding the on button while the phone searches. Then enter 0000 as the pin into the phone when prompted.
Feb 16, 2009 | Samsung SGH-a737 Cellular Phone
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Samsung a920
on your a920
press the menu button,
scroll down and select settings,
press 8,
press 1,
select on,
select 2,
select always visible,
press the back key twice,
which will bring you to the menu
select tools,
press 1,
Note: make sure that your motorolla h500's bluetooth is active and visible to other bluetooth devices
then select add new.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 07, 2008 | Samsung MM-A920 Cellular Phone
Motorola Mobility H500 Wireless Headset Logo
62 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
