You need to hook that to the hot water line...often the dishwasher will work better if you even run water to the sink and get the water hot before starting the dishwasher....they will keep the water hot but do not have a strong enough element to heat cold water hot enough to do a good job for you...
The dishwasher does not heat up the water. The water should be hot coming into the dishwasher, check your hot water supply source, whether it be the hot water tank or be sure the water inlet for the dishwasher is not connected to the cold water line
Connect it to cold water line only, never the hot line, the dishwasher has its own heating element to heat the water to the proper temperature for a clean and sanitized wash.
You are supposed to connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water.
Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has been shut off for a while. If you have questions, please let me know. I hope this helps you.
THE WATER LINE TO THE DISHWASHER SHOULD BE FROM SAME HOT WATER LINE TO THE SINK. RUN THE HOT WATER IN THE SINK UNTIL HOT THEN TURN ON DISK WASHER AND CHECK THAT THE TEMP IS CLOSE TO SAME TEMP. HAVE SEEN COLD WATER LINE USED. YOU SHOULD BE ABLE TO SEE WHICH LINE THAT THE WATER LINE TO DISHWASHER IS CONNECTED.
Your dishwasher water line should be connected to the hot water line not the cold but that wouldn't keep them from drying. You may have a element burnt out or a thermostat bad
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
In my opinion you always connect to the hot water unless there's some compelling reason not to like your dishwasher's manual says to connect to cold. Your dishwasher will heat up whatever water you have connected it to, but since you have a tank of preheated water already sitting in your water heater you should use that.
The "resin in the water softener" example, I think, makes no sense since your dishwasher will heat up the water to something like 160 degrees Fahrenheit no matter if the input is cold or hot...
If I'm not mistaken only hot water goes to the dishwasher. What you have is a valve with two outlets usually 1/4 or 3/8 one goes to supply side of sink faucet and other to the supply line of the dishwasher. This valve connects to the hot water supply line of the house. The stub outs should be close to the D/W. If you want to use cold water then you will have to connect this valve to the cold water supply and then connect one side to the dishwasher and the other to the the cold side of sink faucet. Also I believe that dishwashers need the water to be at a certain temperature +/- 150 degrees. Home Depot/Lowes sell the valves fairly cheap. Hope this helps.
