Just Wireless Bluetooth Headset Wireless Headset Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having trouble connecting BT-K352 with I-phone 3gs
Anonymous
Level 3:
  • Master 425 Answers
  • Posted on Jan 12, 2011
Anonymous
Master
Level 3:
Answers
425
Questions
0
Helped
146701
Points
1419
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Hope that helped..
Thanks for using fixya...
2answers
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Iphone unlock
You can get Remote Unlock service from the site Classicunlocking.com/supported-phones/rs17wp7/ and Unlock I-Phone 3GS from network lock.Then use any GSM Network Sim card....
1helpful
2answers
I just got a new iphone 3gs, having bluetooth
Hi, I have an iPhone also, you don't connect to other phones anymore, like if you did with normal mobile, if say you searched in a full room of people with the iPhone you would just find the printer in the corner!?!?, bizarre i know, but thats Apple for you, (2 steps forward, 5 backwards) you just connect to Bluetooth appliances like, your car, printer, pc/mac.. Thanks Mark
1helpful
Hello sir, Actually i'v lost my cd of
You are probably having trouble in the driver file version or the installing procedure better try the vendor's site here.
Try downloading the driver from above.
Also hang in their FAQ's if you are still having trouble
Regards, WAQAR.
2helpful
2answers
Poor sound quality via Bluetooth mic after switch to iPhone 3GS
Unfortunately, solution is NOT free. Until Apple decides to take good look into this issue, you are left to buying another BT headset model.
I got lucky first time around, bought new Plantronics (not Playtronics...) Voyager 520 (I do love Plantronics 3xx design, this is the next best thing). It did cost almost twice as much as my previous headsets (about 45 EUR), but it's still on the cheap "side" and (to my experience) also the best value.
Hope new headset also lasts almost whole week before needing recharge, like my "old ones". :)
2helpful
2answers
Iphone 3G-S will not connnect to BT Home Hub 2.0
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub.
Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting.
Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether.
Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect.
Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
I have the new iphone 3gs. It currently does not bluetooh pictures/homemade ringtones. Any help?
The procedure for sending the data via BT is hat you make your device and the receiving device visible. Pair with the receiving device by clicking on it. Give the same password to both devices when asked for. Authorise the receiving device. Then you can send as much data as you want.
Top Just Wireless Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
