Garden Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No problems, just need to know what type of engine oil do I use for my ariens 926el . Is it 3 in 1 oil, 4 n 1 oil or what. Looked through manual could not fine the answer
Roy Cagle
Level 3:
President:
  • Master 1,545 Answers
  • Posted on Jan 13, 2011
Roy Cagle
Master
Level 3:
President:
Answers
1545
Questions
Helped
913254
Points
4781
What is Ariens ST 350 engine? A 2 stroke or 4 stroke engine?
It's a four stroke, the engine takes 5w-20 engine oil. Just Google it, there's free manuals online....
http://lawnandgarden.manualsonline.com/manuals/mfg/ariens/932000_series.html
Dec 18, 2014 • Motorcycles
Ariens 624e oil type
Engine- 30w summer
5w-30 winter
Gear case L2 lube, ariens part no. 00008000
Dec 09, 2013 • Garden
My Ariens 1540 will not go anywhere. Engine starts and runs fine but suddenly pushing the steering levers does not make it go. Just got it from a person that says one of the Hydraulic units overheats and...
hi there rermortimer
have you made sure the bypass levers on box hyrdo boxs are disengaged ( that is in the drive mode ) not push / free wheel mode
here is web site to download a owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/ariens/915055_1944_915057_2148_915059_2352_915065_1540_915067_1740_915501_1844_915502_1540.html
in the manual it shows the levers at the rear of machine
it is possible that the units may have o/heated and dropped there additive pack and or the belt that drives the hydro boxs is slipping , check that the box has correct amount of oil and have no air entrained in the oil , ( if it does cavatation is highly possible ) especially if oil has got quite low
alot of heat can be generated from this condition and can damage the pump and motor units in the hydro boxs!!
cavatation sounds quite noisy , makes a knocky / rattley/ rumbly noise , vibration can be felt
in the drive system as air bubbles explode in the oil and is quite damaging to hydro units in itself
may need to drain and refill both units with top quality synthetic type oil which will handle tempreture better , then purge air from units but check simple things 1st
have a look let me know
cheers pauly46
Lawn mower does not like to go up small hills, is there a filter or a place to check the fluid level
It probably doesn't have a factory filter, but I feel ALL small engines should have. The only fluids to check would be the engine oil and maybe the tranmission lube in the little gearbox (if it is self propelled). I don't know how STEEP the hills you mention are, but if too steep, gas flow and oil cirulation will be affected. Try going up the hill at an angle to reduce the problem.
If there is no dipstick tube on the engine to check the oil level, then look for a little yellow cap at the bottom of the engine right above the deck. It is threaded and twists on and off the engine. I think it is made of nylon.Your oil should always be clean, never black. When it starts getting dirty, change it. Most small lawn mowers hold 20 ounces of engine oil (about 2/3 of a quart).
I need to know what type of oil to add to my ariens a173k22 lawn mower
Hi, if it has a Briggs and Stratton engine you need sae 30 engine oil. Regards Phil.
What is the oil capacity on a 19.5 hp ariens riding mower? thank you
This can vary depending on whether or not the engine is equipped with an oil filter. You should have some type of dipstick that will tell you the oil lever. Most engines this size carry about 48 oz.
3helpful
What type oil for ariens st824 do I use?
Check your owners manual for the recommended grade of oil. If you don't have the owners manual, use SAE 30 weight. I prefer Castrol myself. It keeps crude build-ups down. Here is the site to download the manual. Just enter your serial number.
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=gsw0uz210g3q1n45lcz3mtig&site=arienss
Lost manual, what type of oil for ariens st520ec. can I find manual online
Normally, 5w-30 oil is fine for the Ariens line of snow-throwers.
Sep 10, 2009 • Garden
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Top Garden Experts
Jay Finke
Jay Finke
john h
