SOURCE: One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
SOURCE: Schott Ceran cooktop on Maytag range
Need a cleaner for this stove top. What do you suggest?
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: ceramic cooktop repair?
sorry, but no there is nothing available to repair the top. nothing will stay. the material is fired on in the manufacturing process. the only option, (if you can;t live with the blemish is to replace the top.
SOURCE: My Amana ceramic cooktop has
Check your warranty first. Some burners on smooth tops had long warrantys. If not first turn the power off to the unit at the breaker. If this is a in counter cooktop it has to come out of the counter and take all the screws out that hold down the top. Best to unwire from house and move whole unit to big surface to work on.
