SOURCE: My Frigidaire side by side refrigerator is leaking
U SO SMART
WATER DRAIN CLOGGED WHEN IT DEFROST , THE WATER LEAK ING OUT
WATER DRAIN UNDER THE EVAPO COIL
GOOD LUCK
Hello - Typically when water is coming out from under the refrigerator there could possibly be a loose connection from the house water supply line to the water valve or a cracked drain pan (located underneath the refrigerator). Try confirming that the valve is tightened. If the connection is still leaking, turn off the water supply valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. There could also be a loose water connection to the door. This connection is located on the bottom left of the freezer door.
