Need to unblock if posable
If you are limited by the dvd region code, you can get a dvd copy without region code so that you could play it on your dvd player, You could tryLeawo DVD Copy to remove the dvd region code and get a dvd copy.
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
need code
