HI,
Change Language of Operating System
there is 3 method:-
1) Install in English
Instead of using initramfs for booting eeepc use this modified initramfs image:
http://www.roberto.foglietta.name/pub/xepc/en/initramfs.cpio.gz
This setup English localization only if the firstrun does not happen before and the localization would be written down into read-write partition. So this image is useful only during intallation.
2) Automatic Method
locale_dialog can do this for you for English. Go to a terminal: Ctrl-Alt-T and type:
/opt/xandros/bin/locale_dialog
A simple dialog will open with a list of languages. Choose your desired language and press OK buttun (it's the button on the left). The system asks for reboot. Again press OK button (it's the burron on the left). Congratulations!
You may want to uninstall Taiwanese software,or programs, or languagepacks to save diskspace (tested on EeePc701). This does not uninstall the English versions or programs! Go here: http://wiki.eeeuser.com/howto:freespace
The above fails to revert all the dialog boxs to english in eee 701 etc - so see the last paragraph of this help page http://wiki.eeeuser.com/howto:configurefromscratch & change the firstrunwizard and remove the .firstrun file and reboot to an english version eee 701 etc.
3) Manual Method
It is also possible to change to another language, e.g.
(Another editor may be used to modify this file.)
More information on language settings can be found in the i18n document.
i hope this will solve your problem.
goodluck
